For starters, I'm not sure where I should post this question! I'm thinking here because this is where the data for the Shadowdash is being drawn from.... Not sure I need to post the msq file but if it is needed I'll go and get one!
I am running a MS3 with a Microsquirt controlling the 4L60e trans. I have a tablet running Shadowdash and have created some custom dashboards but I don't seem to be able to pull the trans temp data (or any other trans data) back to the Shadowdash. Works fine on the laptop but not on the tablet.
I have done some searching but nothing has jumped out at me with this similar need.
So, the question is; is it even possible to get this trans data to the Shadowdash or am I better off running a second thermocouple directly to the MS3?
Thanks for any help I can get with this.
Setup:
Mazda RX8
LS1 with Bischoff heads and 231/239 cam
4L60e with PTC 3800 stall convertor
8.8 IRS with 3.27:1 gears
Thanks.
Getting Trans temp from Microsquirt to Shadowdash?
