Controlling 2 fans
jleilich
Controlling 2 fans
Post by jleilich »
Hey Guys, I have my fan controller set up and works great. I didnt see an option for a second fan though. I am running one fan right now without a shroud but I may switch to a shrouded dual fan set up. Can I have the fans come on and off at different time? anything else I should know about?
1970 Cuda 440. MS3X
prof315
Re: Controlling 2 fans
Post by prof315 »
You can easily run a second cooling fan with the programmable outputs
Support the developers!
jleilich
Post by jleilich »
I assumed so, but I don't see how to set up controls in tuner studio. I only see the fan control but it doesnt differentiate between two fans.
1970 Cuda 440. MS3X
nathaninwa
Post by nathaninwa »
Look under advanced engine, programmable outputs. You'll us a generic output using clt temp and have the fan come on at the high temp, and give it a hysteris to turn off at the lower temp
jleilich
Post by jleilich »
ah ok, thanks Ill check it out.
1970 Cuda 440. MS3X
jleilich
Post by jleilich »
could you split the output used for the first fan and run that to the relay of the second fan as well so they both turn on and off at the same time?
1970 Cuda 440. MS3X
hiltonlo05
Post by hiltonlo05 »
jleilich wrote:could you split the output used for the first fan and run that to the relay of the second fan as well so they both turn on and off at the same time?
Yes. Would only have one output temperature setting though...no Hi/lo ability
jleilich
Post by jleilich »
You mean they would just come on and off at the same time right? Just like if one fan was wired.
1970 Cuda 440. MS3X
hiltonlo05
The fan output just grounds a relay, you can ground multiple relays with the same output to turn on multiple fans...however... Using programable outputs, you could have one fan come on at say 195, and the second fan come on at say 205...you would have a hi/lo so to speak...or ever better, use the F-body wiring diagram with 3 relays to run both fans in series on low (half speed for both fans) or run them parallel on high (full speed for both fans)...
jleilich
Post by jleilich »
jleilich wrote:.or ever better, use the F-body wiring diagram with 3 relays to run both fans in series on low (half speed for both fans) or run them parallel on high (full speed for both fans)...
any chance someone has a diagram on how to wire this up?
1970 Cuda 440. MS3X
hiltonlo05
hiltonlo05
This is the exact diagram I drew for record of my installation...it may be easier to understand
hiltonlo05
Actually ignore that first diagram, after studying it for a minute, it looks to be incorrect, it's a positive trigger and ms is a ground trigger. Use my diagram
jleilich
Post by jleilich »
sweet thanks
1970 Cuda 440. MS3X
