cel error code.
cel error code.
im using 1.4.0 firmware, i had my cel light light up and i caught it on a datalog, If looking at 'cel status' i get 8 so a tps fault and this is because the adc count is going over my max setting not a problem. But in the same log the 'Cel Error Code' remains as 0 and i don't think thats correct.
Re: cel error code.
Well it only outputs the 'cel error code' if you have the light output set to 'flash codes'
Re: cel error code.
That doesn't sound like expected behaviour.grom_e30 wrote:Well it only outputs the 'cel error code' if you have the light output set to 'flash codes'
Re: cel error code.
Thats how its working for me, i turned on blink codes and 'cel error code' works in the log. i can supply the msq if its needed.
Re: cel error code.
Yes, please post the MSQ, that makes it easier to duplicate the behaviour on the bench.
Re: cel error code.
the only change between no 'cell error code' in the datalog and it working was changing the light output from solid to flash codes in check engine settings.
Re: cel error code.
how did this go?
Re: cel error code.
edit:
i'm still running 1.4.0 i had a quick peek through the later releases and there are no notes mentioning a fix for this, so i guess that this one got forgotten about
