Hi
We run 4g63 stock cas trigger, 4 cop with 4 intern ignitors.
It runs very well but can not rev above 6300 RPM and get lost sync reason 38
Here comes logs
4g63 COP stock trigger Rev issue, lost sync 38
Re: 4g63 COP stock trigger Rev issue, lost sync 38
more logs, engine cuts rpm at 6300-6400 but no sync loss
Mercedes 300E Turbo MS3X 1150hp
http://www.turbobandit.com
http://www.youtube.com/user/PUMPISH
https://www.facebook.com/pages/Turboban ... 24?fref=ts
sync error logger
more composit log with error
Looks like it's losing the CKP signal intermittently. You might need to adjust the pull up or trim pots on the MS3X board.
Matt Cramer wrote:Looks like it's losing the CKP signal intermittently. You might need to adjust the pull up or trim pots on the MS3X board.
Thanks!
By pull up you mean R52 and R56?
I did not know they were useful when using Hall
adjusted 52 and 56 and now can rev up to 7300 rpm
Will try to adjust ms3x pots.
Need 9000rpm rev limit
