Tiny i/ox inside MS3x 3.0?
I want more ADCs but there seems to be very little information out there. I have searched this site, jbperf and Google. There is a lot of info on setting it up to communicate and configuration of i/os, but little on the hardware side. How are people wiring ins and out? Are they using a separate box, etc?
1967 Mustang Coupe, 351w, S475 turbo, MS3.0 3x, c4, 8.8, ls coils, e85
Re: Tiny i/ox inside MS3x 3.0?
You can put it inside the MS3 case either on the bottom under the main board or in the top half. Drill holes in the case to use the TIOx corresponding mounting holes. Just make sure that you have no interference between the TIOx board/components and the MS3 board/components. You'll also have to plan for your wiring and connector(s) for the additional I/Os and for the additional components needed for the I/O circuits on the TIOx (which usually go on the proto area).
You'll also need to connect to 5V, ground, CANH and CANL between the MS main board and the TIOx (the TIOx doesn't have its own 5V supply).
