Sync loss during warmup with SW0205
Re: Sync loss during warmup with SW0205
Postby snowrx » Fri Dec 22, 2017 2:04 pm
Here's files, starting from 27 F, might not be representative as the car started after just a few tries.
"Cold" files are as I first cranked, others are at a cold idle
2017-12-22_12.30.01ColdComp.csv
(473.4 KiB) Downloaded 3 times
2017-12-22_12.29.15ColdTooth.csv
(30.73 KiB) Downloaded 2 times
2017-12-22_12.31.17Comp.csv
(42.54 KiB) Downloaded 2 times
Lotus Esprit w/MS3x ,COP,Sequential,P&H box.GM TB&IAC. VR sensors on 36-2 crank,1 pin cam. MapDaddy,PLX WBO2,Clock&Knock boards.
Subaru WRX hybrid w/MS3PNPPro SW0205,STi cams,VF39 turbo,800cc injectors,VW boost solenoid.
MS3 1.4.1
TS v3.0.10
snowrx
Postby snowrx » Fri Dec 22, 2017 2:07 pm
Rest of files. TunerStudio recorded 32 seperate tiny .msl files while I idled a bit. Started a new.msl with every synch loss, you could string them together and view as a whole. I assume this is because I am triggering the SD with RPM>300, and synch loss = no RPM,
Looks like I am still set on Wasted COP from earlier cam diagnosis.
2017-12-22_12.31.47Tooth.csv
(15.5 KiB) Downloaded 3 times
SW0205Tune .msq
(279.47 KiB) Downloaded 4 times
MS3 1.4.1
TS v3.0.10
snowrx
Postby snowrx » Tue Dec 26, 2017 1:55 pm
Snugged up pin sockets on both cam and crank sensors, then tried one cold start each with a hot air pre-heat of cam then crank sensors. No joy.
Won't have new sensors to test for a bit, not sure what else could be temperature (or time?) sensitive to give me the synch loss on the 32-2-2-2 code.
Datalog is a 29 F start with preheated crank sensor, a couple of start attempts, then cold idle with synch losses until time= 34 seconds, then all is well.
2017-12-26_ColdStart_modified.msl
(541.15 KiB) Downloaded 2 times
MS3 1.4.1
TS v3.0.10
snowrx
Postby snowrx » Wed Jan 03, 2018 2:30 pm
Replaced cam sensor and did a couple cold starts, looks like it helped, now getting synch loss only with initial cranking (or when I stall it engaging clutch on cold tranny)
Hopefully this will now start with two tries rather than 6 or 8 or 10, and quit the stalling. Not sure why the sensor could fail cold, but warm to working temperature in 30 seconds, as it's sensing the back of the cam pulley in air. Perhaps a vibration component as well? Time will tell.
Crank sensor came in today, I'll try that next. It's in the crank oil and I would expect it to warm up faster than the cam sensor.
2018-01-03_ColdStartEdit.msl
(315.36 KiB) Downloaded 2 times
2018-01-02_13_clip.msl
(226.37 KiB) Downloaded 2 times
MS3 1.4.1
TS v3.0.10
snowrx
Postby Matt Cramer » Thu Jan 04, 2018 6:30 am
It wouldn't be the first time I've seen a sensor have a temperature dependent failure with VR sensors. I'm not sure if it is due to thermal effects on the magnet or some sort of expansion / contraction changing the air gap just enough to make trouble.
Postby snowrx » Sat Jan 06, 2018 6:27 pm
Hoping that the cam sensor took care of the issue- still a drop or two while cranking, but not the continuing missing and stalls I had before. Coincidental that it expressed with the swap to the SW0205?
Just cause there are a trillion settings combinations for cold start, don't assume it's a software settings issue until you check the hardware. :roll:
Now on to why my first crank never registers a good AFR on the preheated O2 sensor.....
2018-01-05_12_ColdStart.msl
(404.17 KiB) Not downloaded yet
MS3 1.4.1
TS v3.0.10
snowrx
Postby Matt Cramer » Mon Jan 08, 2018 8:46 am
snowrx wrote:Hoping that the cam sensor took care of the issue- still a drop or two while cranking, but not the continuing missing and stalls I had before. Coincidental that it expressed with the swap to the SW0205?
We don't have quite the same opportunity OEMs have for putting in testing our ECUs with worn, marginal, or partially failed sensors. So the stock Subaru ECU may have had some sort of hardware or software features to compensate for a sensor that was beginning to fail that our system didn't.
The tune has a 40 second delay after start for applying the AFR readings. It is also possible that the supply voltage to the sensor drops far enough to make the controller reset while cranking; many wideband controllers also have a built in delay before they start sending a signal.
Postby snowrx » Mon Jan 08, 2018 10:05 am
Thanks again Matt, I'll look at those O2 thoughts
MS3 1.4.1
TS v3.0.10
snowrx
Previous
Return to MS3 General Support
