Hi, I'm going to turbo my BMW, and was looking for a turbo MAP sensor. During my research I came accros the following MAP sensor: http://www.ebay.de/itm/VW-Ladedruck-MAP ... XQeW5TaoXV .
The sensor looks identical to the one used on the MS3 board, and I wondered if I can replace the standard baro sensor, or if the on board baro sensor is the same type so I don't need to upgrade?
Has anybody used this sensor before for measuring turbo pressure?
Looking forward to any input.
Regards,
Adrian
Turbo MAP sensor
Re: Turbo MAP sensor
Where did you get your Megasquirt from? The standard map sensor on the main board is usually 250kpa.
