Transbrake/bump box wiring
newbie here trying to wire up transbrake with the turbo staging feature. Have read MS manual but it is just flat out not making sense to me!!! If there's anybody that could post up a wiring diagram of how they did it that would be much appreciated.
Re: Transbrake/bump box wiring
Does this help?
Yes kinda does. On my trans brake I have two wires, does the other wire just go straight to chassis ground or does it go to the ground off the relay? Also to make sure I ran the switches right. I have transbrake button setup with one side digital switched 3 and the other side goes straight to ground??? Same with the staging button except using digital switched 2?
Correct about the buttons.
If both wires go to the solenoid, the other end is grounded.
Does anyone have the diagram that was once in this thread?
It was probably the MS3Pro trans brake wiring excerpt.
