I am in the process of upgrading from MS2 to MS3, 351W Ford. I was running EDIS and now going to LS2 coils with a 36-1 VR crank sensor and a 1 tooth VR cam sensor.
MS3/MS3X/V3.57
My first question is can I ground both the crank and cam sensors to pin 1 (VR Crank return) or do I need to run the cam somewhere else?
Thanks!
MS3 VR crank and cam grounding
Re: MS3 VR crank and cam grounding
Common ground is fine, or you could run it to an unused ground pin. Whichever is easier.
dontz125 wrote:Common ground is fine, or you could run it to an unused ground pin. Whichever is easier.
Thank you!
I hope to finish tonight and hopefully get it running
