I'm running Pro with knock wires wired up to each sensor I went to enable knock control today and got a pin conflict error saying the knock wires were being used as a programmable on/off output. I went through the settings and didn't see anything out of sorts
Can you guys look at my tune and see if you see anything. This is on 1.4.1 firmware
knock input pin conflict error
Re: knock input pin conflict error
Looking inside the MSQ, it shows that the tune has "D14" enabled as an on/off output - even though that's not a valid option on MS3-Pro.
Try the attached MSQ.
That new tune took care of it James. Thank you
