MS3Pro On GSXR 1000
MS3Pro On GSXR 1000
Have any one put an ms3pro on a 05 suzuki gsxr 1000. I'm currently in the process and trying to figure out some ignition setting.
Re: MS3Pro On GSXR 1000
I have it on my Hayabusa and should be the same..
Comp65/65 Hayabusa on meth. 358rwhp @7.3psi xxxrwhp@37psi
iv got a k1 engine running on a microsquirt, what specifically do you need to know?
Thanks for the replies. Im trying to make sure I have it all wired right. Here is a run down of what I have done so far.
I have 8 injectors wired a-h, coils wired 1432, 24-2 toothed wheel on wasted cop, running full sequential on spark, staged injection, 6ms dwell time.
you want to wire the coils a-d as per the firing order,
what coils are you running? is it the 2 wire stick coils?
this is not clearon wasted cop, running full sequential on spark
your wiring is wrong.
firing order is 1-3-4-2
Wiring needs to be in firing order for Spark and Injection.
And 6ms is too long for std coils.
I run the 1000 K1 coils with 2.4ms dwell
i thought the firing order was 1,2,4,3
sorry typed the wrong settings. My firing order is 1342 with the injectors running in full sequential. The spark is set to wasted spark, tooth #1 angle (BTDC) 10degrees, Crank Dwell 6.0, spark Duration 6.0
oh sorry yes it is 1-2-4-3
just checked it in the service manual .
thats good news thought i may have been going mad.Speedy_G wrote:oh sorry yes it is 1-2-4-3
tooth #1 105 or so confirm with a strobe, if i remember correctly i had to add 360 to this to make it 465 to get the sequential spark on the correct engine phase.
and if its the stock gsxr coils what are you doing about an ignition amp as the ms3pro cannot trigger these directly.
yes its stock coils with a quad spark ignition module.
Wondering if someone could take a look at my current msq. As of right know the bike starts but I can't seem to get it to Idle correctly.
any chance you can make a log file of it and running? will give more to go on
I wish I could but it won't stay running long enough.
then a log of it starting and cutting out so we can see why
