I am setting up my air shifter this way with shift input as PS1 and output to solenoid as boost output. i test output and wiring from there and all works. input comes from ground thru switch then in to PS1.. can seem to test it or get it working with bike not running. at this time i can not run bike to test. any ideas ? will it not shift with out rpm? i set it to 0 and 0 on tps still nothing.. any help would be great
Derek
sequential shift ??
sequential shift ??
Comp65/65 Hayabusa on meth. 358rwhp @7.3psi xxxrwhp@37psi
Re: sequential shift ??
I'm pretty sure it will not shift without RPM.
that's kinda what i figured but thought there might be way to bench test it?
K guys thanks it needs to be running. tested and working
Try to find a way to simulate the rpm sensor.
Jimstim or modified chain sprokked on lathe, mill, angle grinder.
