Ok in my instructions it states to run jumper wire from PE1 to Spark G. Now my Shift input is PE1 which is a grounding switch aka horn button. is this normal ? seeing I only ground it to shift what does or will it affect. I have been logging by hitting start logging before a run and not using air shift and logs good that way now. since now running and getting dialed in i need to use air shifter.
thanks in advance
Derek
Logger output
Logger output
Comp65/65 Hayabusa on meth. 358rwhp @7.3psi xxxrwhp@37psi
Re: Logger output
What instructions are these?? I don't see that in the Manuals (link above.)
