ECU Temperature reads high?
My new MS3-Pro shows a high ECU temp although, I think it's fine.
I replaced my prior MS3X harness making up a new MS3-Pro harness and tested every wire with a meter.
I left all the loads and sensors unplugged and powered on the ECU to establish initial comm's and found the ECU-Temp reading 200 deg. F right out of the box.
In the generic sensor dialog box, it only offers the GM sensor choice for configuration and calibration.
I've 35 years in electronic repair, so I opened and nothing is even warm. If it's likely a hardware issue, and you would like me to check something, I could send a scope screenshot.
I completed I/O testing and calibration and the car runs fine, with a little finessing of the MS3X code.
It seems the VE table is all shifted, but with the target AFR, autotune and I can fix that.
Thanks So far
Thanks So far
MGB MS3/MSX full sequential and closed loop with cross flow head
Ken Adkison
Shelton Washington
Ken Adkison
Shelton Washington
Re: ECU Temperature reads high?
Does the temp read correctly now that everything is plugged in? Without the sensors plugged in you might have been picking up voltage like a radio antenna, giving the ecu a false reading.
No, My unit seems to be bad.
I emailed support looking for resolution and they are working on a solution.
For EMI protection I'm using "Conductive Cloth Fabric Adhesive Tape LCD Laptop EMI Shielding". You can buy it online.
It is really amazing as it handled the torch flame test better than all the other tapes I have used, is super tough and provides EMI protection.
This stuff looks the business but take longer to wrap and as it is tape makes it harder to bend or upgrade the harness.
Ken Adkison
Shelton Washington
Ken Adkison
Shelton Washington
Did you install all sensor grounds to the white/black wiring to the db37 harness?
Mercedes 300E Turbo MS3X 1150hp
http://www.turbobandit.com
http://www.youtube.com/user/PUMPISH
https://www.facebook.com/pages/Turboban ... 24?fref=ts
I just had the same issue. Brand new MS3-Pro and out of the box the ECU temp was around 200. My MS3-Pro has the wrong resisters in the ECU temp circuit. I had to send mine back for a replacement (its still there). If you want to check it, open the case and check the resistance of R12 and R13 (they are labeled on the board. Mine was 1.242 k ohms for R12 and R13 was 0.188 k ohms. Both were out of spec. I'd wager that they had a bad batch of boards made up with incorrect components.
Call or email DIYAutotune for a repair/replacement.
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
How recently were these ECUs purchased?
Mine was purchased July 12th and has a date of 3/2016 on a sticker attached to the board. See picture below.
http://imgur.com/a/flrta
jsiedlicki wrote:I just had the same issue. Brand new MS3-Pro and out of the box the ECU temp was around 200. My MS3-Pro has the wrong resisters in the ECU temp circuit. I had to send mine back for a replacement (its still there). If you want to check it, open the case and check the resistance of R12 and R13 (they are labeled on the board. Mine was 1.242 k ohms for R12 and R13 was 0.188 k ohms. Both were out of spec. I'd wager that they had a bad batch of boards made up with incorrect components.
As a dealer i recently sold some ms3pro that I source in a similar date. I hope they are good (i guess not). I will ask to customers about this info and deal with this if necessary The big problem here is that I'm living in France, not USA ! It will cost a lot to send units back...
How can this happen since this is a easely controlable parameters ? Tech Edge have a set of tests for EACH device they build to avoid this kind of thing. Maybe DIY should do the same ?
I would not jump the gun and assume all units are bad. Mine is definitely bad and the original poster's seems to have the same issue, but I do not know his production date. As you are a dealer you could open up any units you have in stock and check the resistance of R12 & R13 to know for sure before selling them.
Ken, can you post your production date sticker?
Sure, but this is definitively something I don't want to do !!! As a builder, DIY MUST ASSUME A FULL TEST FOR THERE PRODUCTS. That's all.jsiedlicki wrote:As you are a dealer you could open up any units you have in stock and check the resistance of R12 & R13 to know for sure before selling them.
I'm currently on vacations far from my house and will check this when I'll be back at the office.
Regards,
Manu
I'd say it would be cheaper to have the resistors replaced locally. As well as quicker. it's possible to DIY - unlike say a SM processor which can be tricky.Manu wrote:jsiedlicki wrote:I just had the same issue. Brand new MS3-Pro and out of the box the ECU temp was around 200. My MS3-Pro has the wrong resisters in the ECU temp circuit. I had to send mine back for a replacement (its still there). If you want to check it, open the case and check the resistance of R12 and R13 (they are labeled on the board. Mine was 1.242 k ohms for R12 and R13 was 0.188 k ohms. Both were out of spec. I'd wager that they had a bad batch of boards made up with incorrect components.
Sure you can fix almost anything yourself, but that is not the point. An MS3-Pro unit is not assembled by the user like MS3/MS3X and should not have incorrect components installed from the supplier. You would not buy any other standalone ECU like AEM, Motec etc. and have to crack it open to fix an assembly error.DaveEFI wrote:I'd say it would be cheaper to have the resistors replaced locally. As well as quicker. it's possible to DIY - unlike say a SM processor which can be tricky.
Just a quick note to let you guys know I'm aware of this and we're looking into it-- and we'll take care of people if there was a problem there.
Our final QA test rig is pretty extensive, running each of these ECUs on a live bench with real injectors/ignition coils (sparks flying), fuel pump, IAC, in most cases using actual automotive parts for true-to-life loads. This internal ECU temp 'might' have slipped past the dev team when I asked them to make sure every I/O was tested-- I'm working to determine how it was missed now. Either it wasn't in the test procedure, or the assembly tech didn't follow a step-- and either way I need to, and will, have that corrected.
And we'll have a solution for customers that are effected..... We put this in there as a 'free' helpful diagnostic tool for us internally and never put it on the main features list, but it is in the hardware spec, and it should work. We'll make it right...
Jerry a.k.a. 'FoundSoul'
Founder DIYAutoTune.com / AMPEFI.com
The DIY EFI Tuners Guide – How to Install, Configure, and Tune EFI!
Killer Products We've Brought to Life:
MS3Pro, MSPNP and MS3Pro PNP
More info on MSPNP Models
MicroSquirt AMP'd!
MicroSquirt AMP'd!
Hi Jerry,
I'm back from vacations nd would like to know what components need to be check and what values should they have.
Regards,
Manu
Regards,
Manu
Very true - but you mentioned the time and cost of sending it back for correction. Which could apply to any other make too?jsiedlicki wrote:Sure you can fix almost anything yourself, but that is not the point. An MS3-Pro unit is not assembled by the user like MS3/MS3X and should not have incorrect components installed from the supplier. You would not buy any other standalone ECU like AEM, Motec etc. and have to crack it open to fix an assembly error.DaveEFI wrote:I'd say it would be cheaper to have the resistors replaced locally. As well as quicker. it's possible to DIY - unlike say a SM processor which can be tricky.
There are a few ways to 'skin this cat'. We're working on something that may make it very simple for you all, with no shipping/resistor swapping required hopefully.
We'll keep you posted.
MicroSquirt AMP'd!
MicroSquirt AMP'd!
Hi Jerry,
I have to send an MS3pro today, at least tomorrow, to an customer. I would really like to make it conform. Please tell me what I have to do. Changing 2 resistors is not a problem, even more...
Regards,
Manu
Regards,
Manu
It is just two resistors, what's your email address? I'll have the tech guys, probably Matt, contact you with the info you need.
I'd post it here but I hate the idea of people having to open up these pro ECUs to change anything and typically that's discouraged. We will have a software 'fix' soon I think, but if you want to correct this via a resistor swap that's fine. I just don't want the world to think they need to, as they shouldn't have to and we'll have an easier fix available as soon as possible.
MicroSquirt AMP'd!
MicroSquirt AMP'd!
Hello,
Is there any update about that ?
I'd send my mail as asked, without any reply
We're putting the new software update through testing and debugging.
