Can't get a Barometer gauge to work
Running TS Ultra Beta, I can't get a Baro Gauge to work. I am using a GM map sensor on Ext map for the engine, and the mainboard sensor for baro. I can get both sensors to give me baro readings when set as a map for the engine, but when I assign a gauge to Baro it just sits at 80KPA when real KPA here is 98.X. I can get both sensors to agree on actual baro with the engine off but not when I assign a baro gauge. Thanks for any help.
TS Ultra Beta
MS3X
TS Ultra Beta
MS3X
Re: Can't get a Barometer gauge to work
The only thing that jumped out from your tune is that under "Calibrate MAP/Baro" you have your Baro sensor configured as an MPX4115 sensor - shouldn't that be "GM 1 bar" ? That would throw the reading off significantly.
He is using the MPX4115 (on board) sensor as his baro, and the GM 1 bar as the engine MAP (under the hood), and they are correctly assigned in the General Settings.jsmcortina wrote:The only thing that jumped out from your tune is that under "Calibrate MAP/Baro" you have your Baro sensor configured as an MPX4115 sensor - shouldn't that be "GM 1 bar" ? That would throw the reading off significantly.
Try this to see if it's a gauge problem, with the key ON, open the "Barometric Correction" table/chart and see if it's reading 80kPa there too.
Sticking at 80kPa can happen if the MS3 is reading an "impossible" baro value. Try temporarily setting the allowed min/max baro values very wide to see if the sensor is reporting a value that was outside that range.
Thanks guys, I will try that change for the ranges and see how it works.
Looks like I might have an issue with the main board MAP. I messed with it some tonight and if I assign the mainboard map as engine map I get a reading in the low 40s for KPA. TS will not let you assign the barometer a reading below 60KPA so even when I change the range it will not read. I think I was doing something wrong last night when I was changing sensor assignments to try and get a baro reading.
Oddly enough if I assign my GM map as the baro sensor I get a reading of 105 KPA, if I assign it as engine map I get a reading of 97.7 kpa.
I will worry about this after drag week haha
Last I looked, the main board MAP sensor is a 4250. If you use the calibration for a 4115, then a real-world baro value of 98kPa will result in a reading of around 45kPa. This is lower than the 80kPa limit, so the firmware decides something has gone very wrong, and uses the limit value.
Everything Don said.dontz125 wrote:Last I looked, the main board MAP sensor is a 4250. If you use the calibration for a 4115, then a real-world baro value of 98kPa will result in a reading of around 45kPa. This is lower than the 80kPa limit, so the firmware decides something has gone very wrong, and uses the limit value.
Thank you for the help, switching to the proper calibration fixed the issue. It reads .2 away from the other map sensor now. Thanks again.
