EDIS Wheel indexing
EDIS Wheel indexing
I'm confused because megamanual indicates the EDIS wheel missing tooth should be indexed on the 6th tooth in advance of the missing tooth (for EDIS-6) and this is @ #1 TDC, but Tunerstudio indicates the timing pickup needs to be 10 degrees advanced of #1 TDC. Which is it?
Re: EDIS Wheel indexing
Follow the wheel phasing in the MS3 Hardware Manual.
If you set the trigger/wheel relationship as the manual says, EDIS defaults to sparking at 10 degrees BTDC with SAW disconnected, or no commands from MS. It's a limp home mode. Easy way to check your trigger wheel is positioned correctly - use a timing light with SAW disconnected. It should show 10 degrees BTDC, even with MS not present - just cranking the engine.frontrangeFJ40 wrote:I'm confused because megamanual indicates the EDIS wheel missing tooth should be indexed on the 6th tooth in advance of the missing tooth (for EDIS-6) and this is @ #1 TDC, but Tunerstudio indicates the timing pickup needs to be 10 degrees advanced of #1 TDC. Which is it?
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
So what value do you enter into TunerStudio's trigger wizard for "Ignition Offset angle(deg)" window - 0 or 10?
Zero.frontrangeFJ40 wrote:So what value do you enter into TunerStudio's trigger wizard for "Ignition Offset angle(deg)" window - 0 or 10?
OK, Thanks!
