I have an MS3-Pro and I am not planning on using pin 25 on the white connector (O2 input) and was wondering if that pin can be used for other things? I have not seen anything in the documentation saying it is or is not possible.
Can MS3-Pro O2 input be repurposed?
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
Re: Can MS3-Pro O2 input be repurposed?
Yes 0-5v analog
And where do you find that in TS? I do not see an option in "Generic Sensors" or any other place that will let you select the EGO port for another purpose.
This is not supported in 1.4.x code, but is available in the 1.5 alpha.
