8bit.msq
i have the ms3x with a diyautotune 8 channel can-egt. when the engine is off and key on my egts are at around 46 degrees f. in tuner studio. which is low. air temp today 85 f. now when i open the can-egt temps are also is 46 degrees f. which is to low. the only to make the egt temps right is to change the ADC resolution to 8 bits then the temps are real (87-90). is there a ADC resolution setting (8,10,or 12 bits) in the regular tuner studio to make the egts right?40 degree in egt
40 degree in egt
Re: 40 degree in egt
requires setting this to 10 bits. this makes the TS to show low temps.
Please post the entire project, not just the msq. Use the 'Create Project Backup' option in the vehicle projects menu.
Using 8 bits is definitely not the way to go so the issue is something else.
it says the extension tsproj is not allowed. it seem to take a while to load before the message showed up. im thinking it is to large.
Change the extension to ".zip"
p.s. James, if you read this please change the forum properties to accept the .tsproj files.
i don't know to do a zip file. i never done one.
thanks to youtube you can learn to do a zip file.
It's not the tsproj file but only an msq. What is needed is the tsproj file.
Sorry I guess I'm not very computer savvy. Maybe when I get home today I can have a friend of mine help me with it
try this
Hopefully that's in place now.racingmini_mtl wrote:James, if you read this please change the forum properties to accept the .tsproj files.
i tried loading it and it still says file is to big.
hear is my can-egt file. still can't load zip project file. it says it's to big.
Have you discussed this with DIYAutoTune.com support? I saw you asking about this on Facebook also. Cross-posting blurs the issue.
The default settings on the CANEGT work with MS3 without change if you follow the manual and/or load in the canegt MSQ that is provided with the MS3 firmware zip.
Yes I did discuss it with DIY I talked to a a guy named Ben any said my settings look good and sorry about it posting this twice but I'm I guess I'm just trying to figure out why my egt's are lower than they should be. I'm thinking maybe I need to reinstall the firmware.
good news. i got the readings to read the same (can-egt and tuner studio). something must have been wrong with firmware. reloaded it and
