Anti-lag stopped working on MS3-PRO
Anti-lag doesn't arm anymore or trigger, it suddenly stopped working;
Tried 2 other input wires , nothing changed;
Was running firmware 1.4.0 , upgraded to the latest 1.4.1 , nothing changed;
Checked the 2 fuses inside the ecu, both are good
Anyone had that issue ?
Re: Anti-lag stopped working on MS3-PRO
Oh come on...
Here are the datalogs, please take a lookjsmcortina wrote:Oh come on...
Anyone's got a solution or explanation to why this problem happened ?jsmcortina wrote:Oh come on...
The car is used in pro drifting and it's not competitive without the ALS
Please I need help
Digital Switched 2 remained high (not grounded) through the entire log. The ECU didn't receive a triggering signal.
You mean the ground source is poor, there's no ground ?Matt Cramer wrote:Digital Switched 2 remained high (not grounded) through the entire log. The ECU didn't receive a triggering signal.
Although I tried several other spots...
Is the problem in the ecu ?
I have not seen an internal ECU fault do this. Check the voltage at Digital Switched In 2 with the key on and engine off while turning the antilag switch off and on.
Yesterday I grounded the "DS2" directly to the battery ground, nothing changedMatt Cramer wrote:I have not seen an internal ECU fault do this. Check the voltage at Digital Switched In 2 with the key on and engine off while turning the antilag switch off and on.
Matt asked you to check the voltage levels. Please do that.
Will do asap and report backjsmcortina wrote:Matt asked you to check the voltage levels. Please do that.
Switch off : 0.6Vjsmcortina wrote:Matt asked you to check the voltage levels. Please do that.
Switch On : 12V
It appears your switch has its on-off label on backwards.
Sorry, my mistake, the values are exactly the opposite,Matt Cramer wrote:It appears your switch has its on-off label on backwards.
Switch Off : 12V
Switch On : 0.6V
So where is the problem ?
No ideas what is going on here ?jsmcortina wrote:Matt asked you to check the voltage levels. Please do that.
Check for any loose wires on the antilag input switch. The voltage looks right but it isn't making it into the MS3-Pro.
Tried a Frequency wire and It worked !Matt Cramer wrote:Check for any loose wires on the antilag input switch. The voltage looks right but it isn't making it into the MS3-Pro.
