Since I'm only using the ms3x for spark, for the time being, I wasn't paying much attention to fuel settings, including cranking rpm in Startup/Idle settings. Once I set the value to 700, viola, spark.
I's easy when you know what to look for.
Anyone else run across this stumbling block?
Optispark no spark solved
Re: Optispark no spark solved
Is there a previous thread with some details of the problem (and an MSQ)?
Yes. See - No sync on Optispark
See attached .msq
