What firmware are you using? Not sure what it is, but I tried using a development version and had melted a coil and couldn't get coil output. However, rolling back to the latest stable release fixed my issue. Did the same thing where I sent the ECM in and all they did was change firmware (that price will cover the JimStim cost.)
What firmwares have you tried? Maybe even try a new tune with just enough settings to get an accurate crank signal.
NO Crank Trigger
Re: NO Crank Trigger
MS3Pro Ultimate
1994 Thunderbird SC
Fully Sequential, SVO Odd Fire V6
IGN-1A Coils - Brisk resistor plugs
12 magnet IW wheel (troubleshooting Holley 554-124)
Ford factory half-moon hall effect cam sensor
Using Dual Wheel non-missing tooth crank wheel strategy
Twin Turbo / TH400
1994 Thunderbird SC
Twin Turbo / TH400
