inj duty cycle
inj duty cycle
Hey i have never really logged or looked at My Inj duty cycle. I have ID2000 injectors in the bike now but was originally ID1000 never changed in ecu just adjusted fuel map. could this be causing a false reading on duty cycle in log?/ i have logged from 95-121%
Comp65/65 Hayabusa on meth. 358rwhp @7.3psi xxxrwhp@37psi
Re: inj duty cycle
The duty cycle is the calculated pulse width divided by the time it takes to open the injectors. In practice, a duty cycle of 90% or so generally means the injectors are locked open, and anything over 100% isn't happening, but duty cycles below that are for real.
Re: inj duty cycle
I understand that. better question is anyone have the specs for ID2000 injectors so i can check to see basic info is correct
Re: inj duty cycle
According to https://www.injectorrx.com/injector-siz ... horspower/
You should end up at about 94% DC on meth with with with those ID2000s making 358 HP. You will never support XXX HP at huge boost levels.
Andy
Andy
Re: inj duty cycle
I run base fuel psi at 75psi and i did not log on the dyno as was too quick..i do have a 19.75 psi log @95%.. i am adding 4 more ID2000 just to be safe..
Re: inj duty cycle
Remember that all of those injector calculators are assuming the pressure in the rail is about 42 PSI above the pressure in the intake.
At 15 PSI boost in the intake you are right at 30 PSI absolute in the intake. Add 42 PSI to that and you need 72 PSI absolute in the fuel rail. Subtract 15 psi to get back to gauge pressure in the rail and you get 57 PSI Gauge pressure in the rail to support 15 PSI gauge boost in the intake.
Re: inj duty cycle
PS: there is a rule in EFI tuning 101.... Log everything, no matter what. Logging is not an option, it is keys to the kingdom.
Re: inj duty cycle
I only logged a few things like afr, egt,s IAT, TPS now i am logging every thing. well trying to at least.
