Honda d17a2 spark table msq.
Does any one have a good spark table for a n/a d17a2. I was trying to use an ms3 on my civic but I couldn't get the spark table down, I gave up on megasquirting my car and took evreything out because i was going to swap in a k24a2 but it turns out the motor i bought is blown so while im saving up to kswap my car i would like to boost my little d17. Any help would be greatly appreciated.
Re: Honda d17a2 spark table msq.
Don't know if these will help, but here's some stock tables from hondata s300 for a d16 n/a and boosted.
And also my ms spark table from our boosted b18. If you try my table be careful. I'm no expert. You have been warned
here is the spark table from hondata but my engine still had knock after 4k
No idea about hondata but I know a lot of factory ecu run multiple tables and modifiers. The maps shown so far have been "low speed" and "high speed". Whats the switch point on this?
Cheers Luke
Cheers Luke
The switch point is "vtec crossover" where it switches cam lobes. Defined by rpm and MAPslow_hemi6 wrote:No idea about hondata but I know a lot of factory ecu run multiple tables and modifiers. The maps shown so far have been "low speed" and "high speed". Whats the switch point on this?
BootlegTuned
So it's probably not best to be looking at the low speed map for knock after 4000rpm?
Cheers Luke
Cheers Luke
Depends where the cross over is set to. More aggressive aftermarket cams will want to be crossed over at a much higher RPM then the stock cams. We did a motor car that would dip hard in hp/tq if we crossed over under 7k (13.5-1cr, methanol, 10k limit)slow_hemi6 wrote:So it's probably not best to be looking at the low speed map for knock after 4000rpm?
Being a single cam, the crossover happens much earlier and doesnt have nearly the same impact as it would a 2 cam engine, so yea your probably right.
BootlegTuned
can I drive the vtec solenoid off of the vvt output on the ms3, or do I have to add a relay?
Check its resistance. If it's 6 ohms or more, an MS3X mid current output can drive it directly no problem.
I checked it and its 14.6 ohms can I connect it to the vvt output ? Or which output works off of the mid current driver?Matt Cramer wrote:Check its resistance. If it's 6 ohms or more, an MS3X mid current output can drive it directly no problem.
Yes. VVT is one of the mid current outputs.
Does the frequency matter? Because right now the IAC is set to 512 Hz
My vtec solenoid works off of 12v and the megasquirt is trying to send it ground through the vvt output is there anyway to make it send positive voltage?Matt Cramer wrote:Yes. VVT is one of the mid current outputs.
Use a solid state relay - or a regular relay if it doesn't have to be pulsed.EM2CIVIC wrote:My vtec solenoid works off of 12v and the megasquirt is trying to send it ground through the vvt output is there anyway to make it send positive voltage?Matt Cramer wrote:Yes. VVT is one of the mid current outputs.
I used a 2.5 amp relay but its kind of annoying
I finally installed a knock module and now my engine seems to be misfiring, when i start the engine it runs like crap and doesnt fire on all cylinders but when i rev the engine to like 4k it will idle fine until i start it again. My stock ecu says cylinder number 2 misfire detected. Does any one know what the problem might be? I also installed bigger injectors after i installed the knock module so thats another variable to consider.
I also wired the clutch switch to launch in but for some reason the megasquirt limits the rpm when the clutch in engaged or not. and here is a datalog
Annoying in what regard?EM2CIVIC wrote:I used a 2.5 amp relay but its kind of annoying
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
