2JZ-GTE VVTi poor run on cylinder 3
Hi
Car, Toyota Aristo V300 -98, Holset HX40 Super, BC 264 cams, 1200 cc EV14 injector, original coils and MS3Pro + CAN-EGT (EGT sensor per cylinder)
Problem: Cylinder 3 is run poorly and EGT is over 100 celsius colder then other cylinders.
Tested:
- injectors cleaned and tested -> Good
- coil and plug and wires interchanged
- cylinder compression and leakage is tested -> these are good
- movement of the valves tested and also valve clearance check -> OK
- EGT sensors are swapped and new sensor has been tried -> no effect
- original cams also make that same problem
Is it a possible I make some mistake in MS3Pro setting?
Tested:
Toyota Aristo JZS161 -98
MS3Pro 2JZ-GTE VVTi, Holset HX40 Super
Ofgear + heavy duty transmission with high stall converter
Re: 2JZ-GTE VVTi poor run on cylinder 3
We once bought a "low mileage JDM" 2JZ that we later found out it had two flat top pistons and four dished ones.
I'm thinking there is something mechanically wrong with the #3 cylinder. Try a compression check.
Is that the MSQ you have been running?
The VE table has zero resolution. Does it idle?
The input lag values, including MAP are very low.
Injector size is in as 1000 not 1200.
I think you need to fix lags and injector size, then redo the rows in your VE1 fuel table.
Maybe start from 20 or 30 and go up to 100 in increments of 10, then space the rest out to suit your max boost.
Have you swapped the thrmocouples to see if the problem moves with the thermocouple?
Cheers Luke
Cheers Luke
Sorry I share wrong MSQ file. Now is the latest.
Since you only have problem on cylinder 3 I think you should first try and swap the injectors and coils of that particular cylinder in question with other working ones. Look's like you have already done that. If you hook up a test light on the INJ3 and compare it with let's say INJ1 would you see weaker pulses on INJ3? Finally, you could use the cylinder 3 trim table to up the fuel and see if the egt responds.
I'm positive it's a mechanical issue - if the exhaust valve is stuck close your cyl pressure won't get hurt. Compression test, unfortunately, doesn't help always.
this also has a lot to do with the turbo manifold design. Many times the runners on cyl 3/4 are short and the manifold is NOT equal length. This creates higher back pressure in those runners, which means higher EGTs. See it all the time.
Problem is only with cylinder # 3 and it's misfiring as stated. Short/long runners causing higher EGTs is irrelevant with this case.shaodome wrote:this also has a lot to do with the turbo manifold design. Many times the runners on cyl 3/4 are short and the manifold is NOT equal length. This creates higher back pressure in those runners, which means higher EGTs. See it all the time.
