new project no injector pulse
attached logger and tune files for review
Re: new project no injector pulse
I have a feeling you may have started from a new (blank) project instead of starting from the MS3 example project. This means the values in most of your tables will be nothing like what they should be. In this case your cranking pulsewidth table is full of 1's. You have a bunch of other suspect tables and values as well. I would suggest starting from the example project and modify to suit your needs. Starting from blank is hard work.
Besides the cranking pulse being near-zero (1%), the MAT table is all 0%. There are a lot of other weird things in that MSQ, but the MAT table alone would set PW to zero at all times, even cranking.
If the MSQ is fouled up, then scrub it and load the default MSQ that comes in the firmware zip. Get it from the Downloads link.
thank you bill r and jeff marsh, changed the mat table and got injection pulse, it runs!!! as far as the other strange settings this is a blown fuel methanol funnybike the other functions are not needed
