cmp+ not reading
jsntckr
cmp+ not reading
Post by jsntckr »
I am having trouble getting the cmp+ signal to read at all. I have a gt101 sensor on the crank with 36-2 wheel and on the cam with a single tooth.
The sensor on the crank is reading just fine using the ckp+ wire, 12v power, proper ground and a 1k resistor between power and ckp+
I have wired the sensor on the cam the exact same way using 12v power, good ground, and it's own 1k pull up resistor. I swapped sensors and same result. Only get input through ckp+ wire.
Each sensor reads same voltages and any given time, and signals are both making their way to the pins 6 white and 26 yellow. (Ms3pro)
Ive used the high speed logger to test each. When waving a metal object in front of each, only the ckp+ reads.
Here's the msq, is there a setting I'm missing that will allow the cmp+ to read? Thanks a lot.
Re: cmp+ not reading
Those settings should give a reading. What happens if you take a composite log with the spark mode set to "log crank and cam"?
