Ms3x 1uzfe vvti
Ms3x 1uzfe vvti
Can someone please explain the wiring for this setup. From what I've seen, the builds on here are with mspro and I'd like to know what I need to do to make vvti function with ms3x.
Re: Ms3x 1uzfe vvti
The solenoids themselves should be two pin connections. 1 pin goes to switched 12V while the second connects to a switched to ground PWM output. Polarity does not matter.SupraUZ wrote:Can someone please explain the wiring for this setup. From what I've seen, the builds on here are with mspro and I'd like to know what I need to do to make vvti function with ms3x.
You need to hook up both solenoids to their own medium current outputs on the MS3X. Pin 27 is already labeled as VVT. The other output can go to any spare medium current outputs. Each solenoid will be individually controlled by the ECU.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
Re: Ms3x 1uzfe vvti
Ok and where would i wire my second cam to?
Re: Ms3x 1uzfe vvti
That's the tricky part.
The 1UZ uses a VR sensor while the ECU expects the secondary cam input to come from either PT4, MS3X Cam Input (which is likely already being used as the main cam), JS10 PT5, or Datalog PT6. None of those inputs can accept an AC high voltage signal so you need a VR conditioner to convert the signal to a nice 5V signal.
You can make the circuit in the proto area or, the easier way, use a premade conditioner like the one I linked below.
http://jbperf.com/dual_VR/v2_1.html
Personal Vehicle:
Personal Vehicle:
