AC idle up issue.
AC idle up issue.
Hello !
So i notices my AC idle up want not functioning right. check TS and sure enough the AC "light" does not show it is active ... which is odd, i use too.
checked the wiring, using Nitrous IN. now i had to switch to Inverted, being its a 12v signal to the compressor.
after that it works!!!
BUT
even when the AC is not on, she will activate the AC idle up. starts about 5ish seconds after i start the car, and or it will turn on with the AC, but then will NOT turn off when i switch the AC off.....
thoughts?
BUT
thoughts?
81 Porsche 928. 5L 16v, MS3X CNP- full sequential
Re: AC idle up issue.
Please enable Port Status and take a data log of what's happening.
OK done. here is a data log of the car starting... NO AC ACTIVATION and it AC idle up comes on all on its own about 5 seconds in...
just so darn odd.
just so darn odd.
The nitrous input is already inverted once, so you may be causing problems by "double inverting" it.
Where would the other "inverted" selection be? it just needs to see a 12v input.
switched it back from "inverted". getting a 12v signal to the MS box, but not turning on the AC idle up..... Hmmmmmmmmm i use to work! lol
According to the datalog you posted, porteh is showing 71 and 87.
71=01000111
87=01010111
The first number of the binary sequence is the status of the nitrous input. 0 means the input is "off" (not receiving 12V). That's why your AC doesn't turn on. When you set it to "inverted," 0 now means "on" instead of "off" which explains why the AC now activates on it's own.
I'm curious. You mentioned that you have the ECU wired to see the compressor activation signal with MS having no direct control of the AC compressor. Is it possible that the AC compressor isn't engaging when turned on? Maybe the ECU is working just fine but your AC system isn't working correctly.
71=01000111
87=01010111
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
The AC works like a champ. The Nitrous in line sees 12v when the compressor is turned on via the stock button. when "not inverted", no AC idle up happens with that 12v signal. when i "Invert that" the AC Idle up kicks on with NO 12v signal (AC compressor off)..... thats the conundrum....... and has me scratching my head.
And you've verified that it sees 12V with a multimeter currently? Because according to the log, it's not seeing anything at all at the input.ducman82 wrote:The AC works like a champ. The Nitrous in line sees 12v when the compressor is turned on via the stock button. when "not inverted", no AC idle up happens with that 12v signal. when i "Invert that" the AC Idle up kicks on with NO 12v signal (AC compressor off)..... thats the conundrum....... and has me scratching my head.
Personal Vehicle:
Personal Vehicle:
gets 12v at the engine bay. time to delve a little deeper, check the harness at the MS box.
thank you guys!
thank you guys!
The MS box is seeing voltage......when the AC is switched on...
Hmmmmm
Hmmmmm
It's the same thing with this log too. Porteh status is 87, meaning Nitrous IN is Off.
If you're getting 12V at the connector, maybe there's something wrong internally with that circuit.
Personal Vehicle:
Personal Vehicle:
Ya, thats what i am thinking...........
now to see how i can figure that out.
Well I'm getting current all the way to the connector, no drop in voltage to MS box.
now to open the box and check. which is odd being i changed nothing other than software updates..... Urg.
anyone know where one traces the input on the boards? what to look for what could be wrong? (nitrous in)
What MS2 variant is this?
Ive had problems with nirtous IN just like this. Just stopped working (actually using nitrous)
Ultimately i had to switch inputs
BootlegTuned
Ms3X.Matt Cramer wrote:What MS2 variant is this?
93supercoupe wrote:Ive had problems with nirtous IN just like this. Just stopped working (actually using nitrous)
ya it worked on day... then just stopped...
Sorry, thought I was in the wrong forum. I have seen the 12 volt input get damaged if it is wired to a relay coil or solenoid.
i get the signal off the 12v that goes to the compressor.......... how can one fix that, or tell if it is damaged?Matt Cramer wrote:Sorry, thought I was in the wrong forum. I have seen the 12 volt input get damaged if it is wired to a relay coil or solenoid.
how could i wire up a "ground switch" input for this compressor ? maybe off the relay or something? i dont see any other 12v switched inputs
