Will a Purge Solenoid be okay off an MS3 or ms3x output directly or do you reckon I should go through a relay?
thanks guys.
Purge Solenoid - too much load?
Want a neat way to Check & Set Ignition timing AND CRANK the motor at the same time BY YOURSELF?
A little thing I made up... https://youtu.be/PajlPNF5mmQ
Re: Purge Solenoid - too much load?
It depends on the current draw!!
I found that my NOS branded "sniper" style solenoid drew too much current for the MS3X outputs and they went into current limit mode.
Right. So, the ms3x has safetys build in does it? That sounds handy!
Is there a way I can calculate current draw if I know the resistance of the solenoid?
Ohm's Law. V = IR.Subaru_EA82_4EAT_AWD wrote:Right. So, the ms3x has safetys build in does it? That sounds handy!
Any chance you could dumb that down for me?
...Volts = InternalResistance?
Type Ohms Law into your favourite search engine.
