ve table values not making sense
can some one please check my msq im using incorporate afr table and all my VE table numbers seem to be hanging around 40-50% even in boost to meet my target afr. please forgive the rough looking tune ive only just started
thanks
thanks
Re: ve table values not making sense
Can you post a datalog?
What engine is this and in what car? I see you have it setup as 2JZ VVTI in the ignition settings but VVTI isn't configured. Has VVTI been removed? What is purpose of the various Programmable On/Off and Generic PWM outputs?
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
Your "req_fuel" value is pretty far off. An engine can be made to run fine with an incorrect value there, but yeah, the VE table values "won't make sense".
the engine is a 1mz vvti super charged and truboed same crank/cam as 2jz vvti not using vvti (yet) generic pwm tables are for coolant temp gauge, factory boost gauge & taco (could get it bang on using variable frequency mode) nitrous 1 is for water air intercooler pump others are just basic led indercators will have to make a smaller datalog tomorrow
heres a data-log from yesterday
and a current msq not include afr is now off
Interesting log................ What's going on with TPS? Doesn't seem to move much..............
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
sorry no tps connected yet. the cheap tp has no provision for one but we will get one on at some stage soon
Your req fuel value is still off.
Personal Vehicle:
Personal Vehicle:
