Hi all, been about 10 years since I've worked with megasquirt. I had one of the first MSnS Extras running a custom Turbo motor back in 2004, and, now I've reached a point in a project where a full standalone is called for again.
The vehicle in question is a 2014 Triumph Rocket III Roadster. It has significant engine internal work done and the stock ECU is now the limiting factor, it only allows a peak RPM of 7000, I need to spin the motor to at least 8000 if not 9000 to make full use of the much larger cams.
From what I have seen its a 24-2 trigger wheel, no cam sensor, CDI system. I want sequential injection. The ignition setup uses 3 leads to coils which fire two plugs each simultaneously. There are 3 injectors wich are high resistance.
The IAT and coolant sensors I'll have to replace with GM versions, no big deal. The stock MAP sensor is 1 BAR, just fine, and uses a 0-5 volt linear output as far as I can tell. TPS is a 0-5v system using a linear sensor output.
Is there anything here that you guys can see which will cause any issues? As far as I can tell it should be a very straight forward conversion to MS3 from the stock ECU.
The only sticking point I see that might come up is the IACV. It uses a stepper motor to control idle and resist stalling.
Can MS3 provide sequential injection for a 3 cylinder as described and control the stepper motor natively or am I looking at custom circuitry like I had to do last time using MS?
MS3 on 3 cylinder Motorcycle
Re: MS3 on 3 cylinder Motorcycle
i believe for a 3 cylinder you will also need the cam sensor as well if the 24-2 is mounted on the crank.
You didn't need a cam signal. It works fine with 6-zyl. wasted spark. ;-)
Golf MK1 Cabrio 1,8T MS2
412Hp at 20psi
412Hp at 20psi
Yeah but you have to change the wiring to a different firing order. It won't fire in the ABC order but ACB since it's firing every 120 degrees instead of every 240 degrees.ChristianK wrote:You didn't need a cam signal. It works fine with 6-zyl. wasted spark. ;-)
i assume you need the cam signal for sequential injection.I want sequential injection
Why can't you use the stock IAT & CLT sensors? The service manual should provide you with a 3 point cal and they are likely to be a good bit tidier than the GM units which are very pretty bulky for a bike application.
