Looking through the settings in TunerStudio for VSS Progressive Nitrous. If I have VSS1 and VSS2 installed -- which VSS is the progression based on? I don't see any menu options to select the VSS input.
I'd prefer to use VSS2 vice VSS1 - to allow it to assist with wheelie control and to keep rear wheel spin from adding more nitrous. Application will be motorcycle land speed racing.
Re: VSS Progressive Nitrous
Perhaps use traction control to limit wheel spin and wheelies?
Spent some time reading up on traction control. I didn't realize a wheelie would cause the same VSS "miscompare" as a spin would, i.e. VSS 1 greater than VSS 2. Although the cause is different (VSS 2 decreasing during a wheelie vice VSS 1 increasing during a spin) the resulting power reduction is the same solution for both cases.
Thanks for sending me in the correct direction
