how do i reduce from 16x16 tables to 12x12
steve4179
Post by steve4179 »
hi i am using ms3x on my 2.9 v6 cosworth engine I have the most recent firmware and tunerstudio, the problem I have got is someone has given me pictures of accurate fuel and ignition tables but they are in 12x12 format and mine are in 16x16 on tunerstudio, is there any way I can reduce the size of my tables so I can write the figures into it?
cheers steve
grom_e30
Re: how do i reduce from 16x16 tables to 12x12
Post by grom_e30 »
If you use a ms2 tune you can do a 12x12, copy the map you have the picture of including the rpm and load bins then export the table, then finally import the 12x12 ms2 table in to a ms3 tune and tuner studio scale the 12x12 in to a 16x16 for you
