Tooth logger
Tooth logger
Is there a issue with this?
I cant view yet. Im not sure how to data log yet
Re: Tooth logger
Thats a normal datalog it records all the sensor reading the ecu is getting and also the outputs from the ecu like injector duty cycle ect. you can down load "mega log viewer" from http://www.tunerstudio.com/index.php/downloads to open and view this type of log file.
a tooth log only captures and displays the signal from crank shaft sensor. the log you posted shows the engine reving up to 4050 rpm without any issues of losing sync.
Re: Tooth logger
See the "Forum help page" and read the Manuals.dpetty wrote:I cant view yet. Im not sure how to data log yet
Re: Tooth logger
Hello Grom
I still cant view a data log? can you check this out car is missing at 5000 RPM
Re: Tooth logger
Why not?dpetty wrote:Hello Grom
Re: Tooth logger
I have a MAcBook air
When I open Megalog Viewer MS lite 4.1.10
I click on log viewer it offers no other menu?
Just grey screen that says Megalog Viewer
Re: Tooth logger
You need to open the log file.
File > Open
File > Open
Re: Tooth logger
is there 'file' on the menu bar at the top? no sync loss, maybe you need to tweak the ve table looks like it could do with some work. listen out for pinging as you are running a lot of timing
Re: Tooth logger
Post the MSQ, too.
Re: Tooth logger
here is msq
There are no menues on my viewer?
I will delete the megalog viewer I have downloaded.
Then I will purchase the HD version. Hopefully I can get it going over weekend
Thanks Dave
Thanks Dave
Re: Tooth logger
Get the "lite" version working first. Start a new topic in the "MegaLogViewer" subforum and attach a screenshot so everyone can understand what you are seeing.dpetty wrote:There are no menues on my viewer?
MegaLogViewer is known to work just fine on Windows, Mac, Linux.
Re: Tooth logger
Thanks James
Got it working tonight.
