Twinspark spark timing offset
Twinspark
Post by Twinspark »
Hello,
can MS3x run 8 spark channels for a 4 cylinder, with the two sets of four plugs timed a degree or two apart?
MS3xV30
Alfa 8v TS VVT
ECU built, working on loom
Planned for sequential COP
suberimakuri
Re: Twinspark spark timing offset
Post by suberimakuri »
I wonder if the functionality for rotary trailing spark would work here. You may be limited to wasted spark rather than cop though.
Twinspark
Post by Twinspark »
Thanks Suberi,
what about oddfire phasing?
MS3xV30
Alfa 8v TS VVT
Twinspark
Post by Twinspark »
From TS manual:
Custom oddfire angles in sequence from #1
• 1st – Number of crank degrees engine rotates from spark A to spark B;
• 2nd – Number of crank degrees engine rotates from spark B to next cylinder;
• 3rd – Number of crank degrees engine rotates from spark C to next cylinder;
• 4th – Number of crank degrees engine rotates from spark D to next cylinder.
Set up something like this:
Cylinder 1 A and B - 2 degrees
B to C - 178 degrees
Cylinder 3 C and D - 2 degrees
D to E - 178 degrees
Cylinder 4 E and F - 2 degrees
F to g - 178 degrees
Cylinder 2 G and H - 2 degrees
Is this likely to work?
MS3xV30
Alfa 8v TS VVT
suberimakuri
You're welcome.
In fact you could probably use trailing spark like on a quad rotor and still have cop mode as such.
Nothing wrong with wasted spark though.
Sorry I don't know anything about odd fire.
2 degrees is not a lot of split?
What's the engine?
suberimakuri
Actually it looks like trailing timing support is limited to rotary engines only and rotary must be selected in the engine settings.
Perhaps a feature request to enable this might work for you?
Post by Matt Cramer »
Currently trailing spark is a rotary-only feature. It may be added for piston engines in the future.
