ms3 pro car starts run's then stalls
have installed a ms3 pro into my car cant get it to run sounds as though timing is wrong, running full sequential and individual ing-1 coil packs with a dual vr sensor set up 36-1 crank wheel and one tooth cam wheel. on tooth logger it seems good on cranking but when I plug injectors up to give it fuel when it fires and rpm raises the tooth logger has lost sync.
Re: ms3 pro car starts run's then stalls
Try "wasted COP" for spark mode, and...
all good fixed it had the wrong polarity on vr sensor switch wires changed edge and all ok
