Bmw wiring
timmy325is
Re: Bmw wiring
Post by timmy325is »
Thanks I'll try that
Sent from my SM-G900V using Tapatalk
92 BMW 325Is M50 build, , MS3X v3.57 firmware 1.5, full sequential fuel and spark , LS2 Coils
grom_e30
Re: Bmw wiring
Post by grom_e30 »
that should cause the dme relay to power on with the key so you should get 12v to the injectors the icv fuel pump relay and so on. you should also get 12v on pin 54 that's the 12v supply you want to power the ms from, not the green wire on 56
timmy325is
Re: Bmw wiring
I tried that. The relay clicks but still no fp. I read that Fidle does the same thing as that transistor combo I just tried. I get 12v to the injectors
grom_e30
Re: Bmw wiring
Post by grom_e30 »
so are you getting 12v on the red + white wire on the fuel pump relay now?
timmy325is
Re: Bmw wiring
No I'm getting 1.8v on the red& white of the fp. And the brown relay wire has 12v
grom_e30
Re: Bmw wiring
Post by grom_e30 »
on the fuel pump relay:
pin 30 on the relay should be a red wire constant 12v
pin 87 power to the pump green and violet
pin 86 red and white switch live powered by the dme relay
pin 85 brown and green signal wire pin 1 on motronic connector.
if you remove the relay you should have 12v on pin 30, and an ignition 12v on pin 85. if that checks out put the relay back in and with your megasquirt disconnected try grounding the brown and green wire to see if the pump runs.
timmy325is
Re: Bmw wiring
The pump runs when I jump the relay
grom_e30
Re: Bmw wiring
Post by grom_e30 »
what do mean by jumping the relay? connecting pins 30+87 together?
timmy325is
Re: Bmw wiring
Grounding pin 85
grom_e30
Re: Bmw wiring
Post by grom_e30 »
ah ok so sounds like the wiring it there maybe look at the ecu next
timmy325is
Re: Bmw wiring
grom_e30 wrote:ah ok so sounds like the wiring it there maybe look at the ecu next
I've got continuity between pins on Q2. That's never good... that could be my problem
grom_e30 wrote:on the fuel pump relay:
grom_e30 wrote:so are you getting 12v on the red + white wire on the fuel pump relay now?
timmy325is wrote:No I'm getting 1.8v on the red& white of the fp. And the brown relay wire has 12v
93supercoupe
Re: Bmw wiring
Post by 93supercoupe »
Grom is doing a great job here, but there is a much easier way to get the main relay to switch.
Hook pin 54 from the car side to your 12v on your MS
Take a normal relay, and take pin 56 on the dme and hook it pin 85 of the relay.
Pin 86 of the relay goes to ground
Take pin 27 of the dme goes to relay pin 30
Relay pin 87 also goes to ground.
Once you switch the main relay, the FP and O2 relay will switch with it. At that point, your coils, injectors, vanos should have 12v.
First tooth agle is 84 on all US 24v engines (for the most part, except the non vanos early 92's)
Ive attached a little document ive done for these cars. Intead of the tranisotr setup you will see pictured, i use a relay. Ive done about 10 of these so far like this and they work fine.
Again, not taking anything away from Grom as he has given very good info in here.
BootlegTuned
grom_e30
Re: Bmw wiring
Post by grom_e30 »
funnily enough i originally used a relay to provide ground to turn the dme relay on..... but i found that on a low battery during cranking the voltage droop would sometimes cause the relay to turn off cutting power to the ecu and injectors ect and made starting the car difficult. the transistor requires less voltage and solved that issue.
93supercoupe
Re: Bmw wiring
grom_e30 wrote:funnily enough i originally used a relay to provide ground to turn the dme relay on..... but i found that on a low battery during cranking the voltage droop would sometimes cause the relay to turn off cutting power to the ecu and injectors ect and made starting the car difficult. the transistor requires less voltage and solved that issue.
Ive heard that before but have never seen it myself. Even in New England winters
BootlegTuned
timmy325is
Re: Bmw wiring
Thanks to both of u for all the great info! I'll try that tonight. This m50 is non vanos pretty sure it's the same 1st tooth angle.
timmy325is
Re: Bmw wiring
Didn't see the attached document tho
93supercoupe
Re: Bmw wiring
it wouldnt allow me to attach. Shoot me a PM with your email and ill send it over.
BootlegTuned
timmy325is
Re: Bmw wiring
Huge Props- 93supercoupe and Grom for being stand up guys and sharing your knowledge. I appreciate everything... merry Christmas!!! That's what these pages are about.
93supercoupe
Re: Bmw wiring
Just pay it forward man!
Good luck and merry Xmas
BootlegTuned
