Old school Ford Alternator wiring
I am hoping to have my ms3pro regulate the alternator output. I have a 80’s style ford alternator that has an external regulator. The alternator has two wires, battery and field. From what I understand as the voltage to the field terminal increases the output of the alternator increases. When I read up in the Ms3pro manual, I am not sure if it is able to produce a variable output that I can wire to the field terminal. My question is has someone been able to use the Ms3Pro and an 80’s ford alternator and if so how did they wire it and what settings to use. Thanks in advance
Re: Old school Ford Alternator wiring
That sounds like Chrysler alternators.
Wiring would be similar to MS3X/V357, see here:
http://www.msextra.com/doc/pdf/html/MS3 ... .4-53.html
I'd want to see an internal diagram of the alternator.
Sent from my XT1080 using Tapatalk
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
the fords use a high side driver on the field
So he'll need a P channel FETashford wrote:the fords use a high side driver on the field
Peter Florance
PF Tuning
PF Tuning
Thanks for the responses. I still am a little confused. The Link to the Chrysler use three terminals. I am only using two. Battery and field. Also I thought all the high current outputs where grounds. That they are basically ment to control the ground on a relay ie cooling fan, or ground to an injector. If I where to power the field through a relay it would be either on or off not variable.
Any idea of the resistance of the field coil?
Peter Florance
PF Tuning
PF Tuning
See the next page in the manual for high-side control. The output is pulsed. I've personally bench-tested the Chrysler configuration.Dgus wrote:Thanks for the responses. I still am a little confused. The Link to the Chrysler use three terminals. I am only using two. Battery and field. Also I thought all the high current outputs where grounds. That they are basically ment to control the ground on a relay ie cooling fan, or ground to an injector. If I where to power the field through a relay it would be either on or off not variable.
Peter Florance
PF Tuning
PF Tuning
Thanks. I will give this a try.
