There is a lot of info around on configuring and datalogging JS4/ADC7 for a variety of sensors (knock/map and temp). The details always refer to ADC7 in the MS ini file. I however can not find in my ini file any reference to adc7 to configure the outputchannels and then datalogging sections. I am using vanilla MS 1.4.1 (MS3 Format 0524.050 )on old MS2 hardware using a MS3 dauhtercard ecu
I am running water injection (Aquamist) by configuring a PWM output channel to the Aquamist ECU...this inturn triggers a PWm valve to spray water. This works fine. Aquamist can send a signal to MS when it detects an error and goes into failsafe mode. I have configured this signal to JS4/ADC7 and used this to tableswitch my Ingition table. This too works fine and my advance table (3) is selected when the JS4 signal is grounded.
I would like to log this event (the status of JS4) so I can log the failsafe condition. or possibly as an alternative the tableswitch trigger triggered by JS4 state change.
Thanks..
Logging JS4/ADC7
Re: Logging JS4/ADC7
When used as a digital input, that pin is connected internally to "PORTAD" it doesn't appear to be dataloggable currently.
The tableswitch status is one bit within status1 which is logged. See http://www.msextra.com/doc/pdf/html/Meg ... .4-61.html
look for 'generic sensor inputs' in the manuals it will show you how to set them up
Thank You!!!!..that has pointed me in the right direction..
Just closing this off.
As per James' detail. status1 contains the bit value for which spark table is being used
indicator = { status1 & 64}, "SPK1/2", "SPK3/4", white, black, green, black
then a custom.ini mod logs this bit value
[OutputChannels]
Tableswitch = { status1 & 0x40 }
[Datalog]
entry = Tableswitch, "Tableswitch-Spark", int, "%d"
[OutputChannels]
[Datalog]
