Hi all,
I've built a stroker engine for my 1967 Dodge Charger, running on E85 with full sequential contol. All works well.
Since I want to have the original tach fully operational, I bought an MSD 8920 interface adpter, which is fed from the MS3X tach output and outputting the signal to the (originally ignition coil triggered) tach. Running a bench test the 5krpm on MS3X read 5krpm on the tach...all was well so far...
But, to my surprise, installing all in the car the original tach now reads approx 1000 rpm too high over the whole scale!
Is there a way in software or hardware to modify the MS3X tach output to set the old tach to show correct readings?
Martin
Original tach showing too high rpm w. MS3X
Martin, Sweden
Mopar 512 cui, 8.4 liters, high compression, fuel E85, full sequential control by MS3X, burning rubber just blipping the throttle...
Re: Original tach showing too high rpm w. MS3X
In "Basic/Load Settings," there is a "Tacho Output" menu. If you switch it from "Fixed" to "Variable," you can set a percentage adjustment value for the tach signal.
If you're saying the value is a constant 1000rpm high over the entire band, you might just need to adjust the needle. Was it accurate with the original setup?
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
Thanks a lot for the reply.
I calibrated the original tach with a signal generator a few years ago so it was pretty accurate at the time. It was however not possible to set it perfectly...it wasn't entirely linear but showed an S-curve around the correct values.
Setting the duty cycle in software seems perfect, I just want the tach to show reasonably correct readings.
Thanks again, I'll have a look at it tomorrow!
Martin
Martin
Martin, Sweden
Yep, setting the duty to 63% and all works beautifully!
Thanks,
Martin
Thanks,
Martin
Martin, Sweden
