So. After I got the CAM signal to behave, it seem that the engine will misfire and throw Sync Errors when I rev it to approx 2500-3000rpm.
It looses out on the crank signal.
What can it be, I tried to change the sensor itself just to make sure that wouldn't be the problem, but to no change.
This is a view of the logging, as can be seen to the very right, there is an extra large gap compared to the other gaps in the 60-2 signal, probably more like 3 missing teeth instead of 2. Please ignore that the CAM signal is not perfect on this one, was testing some other filtering settings just on the CAM signal on this occation.
Adding a composite logfile here, sadly had to .zip it as it was too large for the forum uncompressed (~3mb).
Are there any tweaks that can be done in the software? I tried to enable the simple filtering algorithm with not too large usec values on the curve defined, but it seemed to do the signal more unstable.
Is it possible to add some resistors somewhere in the system as I did on the CAM sensor to make the signal stable?
I didn't think it should be necessary though as the complete loom from plug to Bosch ECU plug is factory install and MS3 Pro module is just added inside the ECU box.
Unstable Crank signal 60-2, OEM loom with shielding
Re: Unstable Crank signal 60-2, OEM loom with shielding
60-2 usually needs a 10k across vr+/- be it in the ecu or loom on micro and pro.
Ah, thanks, I've been fiddling with the noise filters etc. but no success.
Just now I took the bother to read the manual which also states this about the 10k resistor if it gets unstable at higher revs, which is exactly my problem.
I'll give it a try and see what happens. Hopefully success... will report back when I've tried it.
Btw. How is it possible to plot the raw VR signal before processing?
I couldn't find it in the log file.
Soldered in a 9.6kOhm resistor and problem totally gone, no need for any filtering in the software
Good to hear!
