gjestico wrote:What front accessory drive do you have ? F body, Corvette or truck ? That will affect how much room you have for the wheel behind the balancer.
I was thinking of doing something similar, Its fairly easy to CAD up any size wheel you can imagine and get it water jet cut from plate for surprisingly cheap.
I have the F-body setup.
I was thinking of mounting the wheel to the front of the pulley, so I don't have to move my accessories forward to maintain belt alignment.
I also want to do this fairly inexpensively, as it's only a temporary setup to run this summer.
I guess I'm not really tied to 60-2 either, as it would be simple to change that config in SW later.
I see DIY Autotune has some generic 36-1 wheels available pretty cheap.
It should only require a spacer and a longer damper bolt to make something like that work.
Thanks guys, this is putting me in a much better mood.
