strange tooth angle
strange tooth angle
Hello. I use ms3x 60-2 and single tooth cam. Previously angle was 691 and this work good. After engine rebuild changed crank sensor position, but cam sensor and cam tooth stay on. Use strobe angle was 541. Tooth #1 angle this angle between cam signal and TDC, right?(from manual) Or from first tooth after cam signal to TDC(strobe)? Thank you, and sorry for bad English.
Re: strange tooth angle
On a missing tooth wheel, the angle is the position of the first crank tooth after the missing teeth relative to TDC. The cam tooth only determines phase.
Personal Vehicle:
Personal Vehicle:
Thank you
