I am playing within TunerStudio as I am wiring my car to ensure I am wiring what I can do with the ECU properly.
What I Want: 2-speed fan operation
- If Coolant Temp >200* turn on low speed fan.
- If Coolant Temp is >210* OR the A/C is on, turn on the high speed fan
I believe I can do the following but am not sure how to get there completely.
High Speed Fan: Black Plug Pin 33 to control the High-speed fan relay via this configuration:
A/C Input: I believe the "Nitrous In" [Gray Plug, Pin 10] pin can handle a +12v signal, correct? If so, I would like it to reference my A/C Compressor power as an input. To me this setting shows that Nitrous 1 is my "A/C Input" but it will not actually do anything with it in this screen, only the Fan control is looking at that input.
Low Speed Fan: Using Nitrous 1 output, Pin #10. To me this should be "On" >=200°, "Off" <200°F or >210°. Will this work?
