Benchtested the following setup to see if I can take-over the ignition-timing with MS, but the MS is having no control over the HEI-7 module it seems.
The setup, when operational, generates sparks just fine because the HEI-7 is running the show in bypass-mode, but the MS3 is seeing no RPM-signal, and can't therefore modify timing.
Double checked the wiring / connectors and such.
Trying to find out what what's wrong, and to check next.
Eventually the MSx3 will installed and be used for Ignition only.
- MSx3, prepped for vr-input, adjusted/connected according to manual, chapter 6.4 & 5.2.6. (Adjusted R56 to read 2.5v on R54).
- HEI 7-pin module.
- Chrysler electronic distributor (vr), mounted in a lathe, running 1100rpm.
- MSD TFI e-coil, with a sparkplug installed on a short leadcable.
Pin 24 on the V3 has about 5v. Pin 14 (SPK-A) and 33 (SPK-B) show nothing.
Also, reading the MSx3 manual, p125/126:
Typical Settings
Spark mode = "Basic Trigger"
Ignition capture = "Rising Edge"
Spark output = "Going High"
Spark A output pin = "MS3X spark"
Dwell type = "Standard Dwell"
Nominal Dwell = "3.0"
GM/HEI options = "GM bypass"
About the last line, I can't find this option in the Ignition settings in TS.
Is this a relic from an older manual setting maybe, or am I missing something?
Benchtesting MSx3, HEI-7, vr-distributor - No RPM input?
Re: Benchtesting MSx3, HEI-7, vr-distributor - No RPM input?
How have you connected the HEI module to the MS?
Have you added the jumpers internally, to connect the db37 pins to the correct internal hardware?
Tha Daily: 2005 Chevy Blazer
I haven't installed any jumpers myself. I bought the MS3x some years ago, pre-wired for VR-input, which checked out (internal wiring).
(The MS3x can read the vr-signal/RPM from the (rotating) distributor in a standalone setup with no problems).
Want to start using the MS3x on my daily driver (1973 Dodge Dart), so like to use the HEI-7 setup, so it's easy to switch back and keep the car drivable, in case of possible issues.
I did check/follow the wiring into both connectors for pin 24, and pin 14 and 33 for SPK-A and B, but did not check for jumpers (didn't see any mention in the manual for this).
The MS3x only connection to the module is through the 3 pins on the HEI module (B,R, E).
Hooked up the wiring according the pic below;
It is now called:BigBlockMopar wrote: GM/HEI options = "GM bypass"
HEI/GMDIS, TFI, C3I Options
Thanks James.
The mention of 'adding jumpers and wiring', made me look into the manual a bit more.
Until now I had primarily looked into the MS3'Extra' manual, but I just noticed, in the MS3 'Base' manual, on p122, the same info on HEI-7, only WITH board modifications mentioned. These are however not mentioned in the MS3'Extra' manual.
I'm confused now if this has been left out on purpose, or this is just an error (I know how tedious it can be creating a manual).
Also the advised Ignition settings appear to be different;
The Base manual mentions Spark output = "Going Low", while the Extra manual says: "Spark output = "Going High".
I will have to check tomorrow if my MS3x has these mods done at the time or not.
Different hardware.BigBlockMopar wrote:The Base manual mentions Spark output = "Going Low", while the Extra manual says: "Spark output = "Going High".
The MS3X manual is using the Spark outputs that are pre-made on the MS3X card.
The MS3 base manual requires you to customise to create spark outputs.
