So im finishing up a MS3 on a subaru and I have my check engine ouput wired up to a check engine light, I have now enabled it and im enabling each of the sensors i want it to check.
What should the normal values or procedure to know the values be(are they counts or volts)? fluctuation values?
Im using the diyautotune 4bar map sensor
GM IAT sensor
the subaru CLT sensor which is already calibrated on the thermistor and reading fine all the way to 100C
The subaru tps
battery
sync loss count
thanks in advance
Check engine light general setup
Re: Check engine light general setup
I can see the tps ADC but not the other sensors?
My setup, I found the EGO too troublesome so disabled. This seems to behave OK but it is hard to say because i haven't had say map sensor fail to validate it is going to work.
It is a start which I hope you see preferable to no response at all
http://web.aanet.com.au/arran
See in the bottom right of the settings page. You can make "status5" show the fluctuations or ADC count for each of the sensor inputs.jasaircraft wrote:I can see the tps ADC but not the other sensors?
thanks guys i will try all that
