what trigger wheel?
Blue 12
Re: what trigger wheel?
Post by Blue 12 »
the sensor used for the 8 tooth and 24 tooth wheel is the same
Assemblies where 21176-1077 is used
1998 NINJA ZX-9R (ZX900-C1) - Ignition System
1999 NINJA ZX-9R (ZX900-C2) - Ignition System
2000 JET SKI 1100 STX D.I. (JT1100-C1) - Generator
2000 NINJA ZX-12R (ZX1200-A1) - Ignition System
2001 JET SKI 1100 STX D.I. (JT1100-F1) - Generator
2001 JET SKI ULTRA 130 D.I. (JH1100-B1) - Generator
2001 NINJA ZX-12R (ZX1200-A2) - Ignition System
2002 JET SKI 1100 STX D.I. (JT1100-F2) - Generator
2002 JET SKI ULTRA 130 D.I. (JH1100-B2) - Generator
2002 NINJA ZX-12R (ZX1200-B1) - Ignition System
2003 JET SKI 1100 STX D.I. (JT1100-G1) - Generator
2003 JET SKI STX-12F (JT1200-B1) - Ignition System
2003 JET SKI ULTRA 130 D.I. (JH1100-B3) - Generator
2003 NINJA ZX-12R (ZX1200-B2) - Ignition System
2003 Z1000 (ZR1000-A1) - Fuel Injection
2004 JET SKI STX-12F (JT1200-B2) - Ignition System
2004 JET SKI STX-15F (JT1500-A1) - Ignition System
2004 JET SKI ULTRA 130 D.I. (JH1100-B4) - Generator
2004 NINJA ZX-12R (ZX1200-B3) - Ignition System
2004 Z1000 (ZR1000-A2) - Fuel Injection
2005 JET SKI STX-12F (JT1200-D1) - Ignition System
2005 JET SKI STX-15F (JT1500-A2) - Ignition System
2005 NINJA ZX-12R (ZX1200-B4) - Ignition System
2005 Z1000 (ZR1000-A3) - Fuel Injection
2005 Z750S (ZR750-K1) - Fuel Injection
2006 JET SKI STX-12F (JT1200D6F) - Ignition System
2006 JET SKI STX-15F (JT1500A6F) - Ignition System
2006 Z1000 (ZR1000A6F) - Fuel Injection
2006 Z750S (ZR750K6F) - Fuel Injection
2007 JET SKI STX-12F (JT1200D7F) - Ignition System
2007 JET SKI STX-15F (JT1500A7F) - Ignition System
2007 JET SKI ULTRA 250X (JT1500B7F) - Ignition System
2007 JET SKI ULTRA LX (JT1500C7F) - Ignition System
2008 JET SKI STX-15F (JT1500A8F) - Ignition System
2008 JET SKI ULTRA 250X (JT1500B8F) - Ignition System
2008 JET SKI ULTRA LX (JT1500C8F) - Ignition System
2009 JET SKI STX (JT1500D9F) - Ignition System
2009 JET SKI STX-15F (JT1500A9F) - Ignition System
2009 JET SKI ULTRA 260LX (JT1500F9F) - Ignition System
2009 JET SKI ULTRA 260X (JT1500E9F) - Ignition System
2009 JET SKI ULTRA LX (JT1500G9F) - Ignition System
2010 JET SKI STX (JT1500DAF) - Ignition System
2010 JET SKI STX-15F (JT1500AAF) - Ignition System
2010 JET SKI ULTRA 260LX (JT1500FAF) - Ignition System
2010 JET SKI ULTRA 260X (JT1500EAF) - Ignition System
2010 JET SKI ULTRA LX (JT1500GAF) - Ignition System
2011 JET SKI STX-15F (JT1500ABF) - Ignition System
2011 JET SKI ULTRA 300LX (JT1500JBF) - Ignition System
2011 JET SKI ULTRA 300X (JT1500HBF) - Ignition System
2011 JET SKI ULTRA 300X (JT1500HBFA) - Ignition System
2011 JET SKI ULTRA LX (JT1500GBF) - Ignition System
2012 JET SKI STX-15F (JT1500ACF) - Ignition System
2012 JET SKI ULTRA 300LX (JT1500JCF) - Ignition System
2012 JET SKI ULTRA 300X (JT1500HCF) - Ignition System
2012 JET SKI ULTRA 300X (JT1500HCFA) - Ignition System
2012 JET SKI ULTRA LX (JT1500KCF) - Ignition System
2012 JET SKI ULTRA LX (JT1500KCF) - Ignition System(KCF∼KFF)
2013 JET SKI STX-15F (JT1500ADF) - Ignition System
2013 JET SKI ULTRA 300LX (JT1500JDF) - Ignition System
2013 JET SKI ULTRA 300X (JT1500HDF) - Ignition System
2013 JET SKI ULTRA LX (JT1500KDF) - Ignition System
2013 JET SKI ULTRA LX (JT1500KDF) - Ignition System(KCF∼KFF)
2014 JET SKI STX-15F (JT1500AEF) - Ignition System
2014 JET SKI ULTRA 310LX (JT1500MEF) - Ignition System
2014 JET SKI ULTRA 310R (JT1500NEF) - Ignition System
2014 JET SKI ULTRA 310X (JT1500LEF) - Ignition System
2014 JET SKI ULTRA 310X (JT1500PEF) - Ignition System
2014 JET SKI ULTRA LX (JT1500KEF) - Ignition System
2014 JET SKI ULTRA LX (JT1500KEF) - Ignition System(KCF∼KFF)
2015 JET SKI STX-15F (JT1500AFF) - Ignition System
2015 JET SKI ULTRA 310LX (JT1500MFF) - Ignition System
2015 JET SKI ULTRA 310R (JT1500NFF) - Ignition System
2015 JET SKI ULTRA 310X (JT1500LFF) - Ignition System
2015 JET SKI ULTRA 310X (JT1500PFF) - Ignition System
2015 JET SKI ULTRA LX (JT1500KFF) - Ignition System
2015 JET SKI ULTRA LX (JT1500KFF) - Ignition System(KCF∼KFF)
2016 JET SKI STX-15F (JT1500AGF) - Ignition System
2016 JET SKI ULTRA 310LX (JT1500MGF) - Ignition System
2016 JET SKI ULTRA 310R (JT1500NGF) - Ignition System
2016 JET SKI ULTRA 310X (JT1500LGF) - Ignition System
2016 JET SKI ULTRA 310X (JT1500PGF) - Ignition System
2016 JET SKI ULTRA LX (JT1500KGF) - Ignition System(KGF)
2017 JET SKI STX-15F (JT1500AHF) - Ignition System
2017 JET SKI ULTRA 310LX (JT1500MHF) - Ignition System
2017 JET SKI ULTRA 310R (JT1500NHF) - Ignition System
2017 JET SKI ULTRA 310X (JT1500LHF) - Ignition System
2017 JET SKI ULTRA 310X (JT1500PHF) - Ignition System
2017 JET SKI ULTRA LX (JT1500KHF) - Ignition System
I dont have any more of the 24-1 wheels, i had one and cut it up to make the 12-1
i am open to knowing why the zx14 wheel is better. i do like learning. however it doesnt fit what i have.
i tried the main board crank input circuit today and nothing registered, so i put it back on the jb perf board and got very limited inputs. it fired up once, and seemed ok, then when i shut it off it would not restart. barley showing any blips during cranking
2000 ZX-12R LSR turbo Worlds Fastest at 266.5MPH on board video here https://www.youtube.com/watch?v=CruXgKKzBUs
Blue 12
Post by Blue 12 »
im at the point where i want to scrap the idea of using vr sensors and maybe try a hall
Blue 12
Post by Blue 12 »
as a test i did the required main board adjustments (jumpers and resistor) and held a hall sensor up to the crank wheel while my gf hit the starter button(cois and inj unplugged). it displayed rpm fine. im going to build a bracket to hold a hall sensor in here and maybe this struggle will end.
grom_e30
Post by grom_e30 »
usually vr sensors are better for high rpm. how about some logs? can you scope the input an the output of the vr board?
Blue 12
Post by Blue 12 »
how would a hall sensor do with an 8 tooth wheel at 13000 rpm?
no i cant scope anything :cry:
dontz125
Post by dontz125 »
It depends on the sensor. Most of the Gear Tooth Sensor datasheets I've seen have max pulse rate numbers in the 15-20 kHz region, while your example is a mere (13,000 / 60 x 8 = ) 1.7 kHz.
As for the comment of VR sensors being better for high revs, I've never seen a Hall sensor require a shunt or series resistor to eliminate sync loss at moderate (5k+) rpms. I *have* seen a Hall sensor provide a cleaner, more consistent signal with a 12v pull-up vs 5v.
kaeman
Post by kaeman »
I have turned my 36-1 tooth wheel more than 8000 rpm using a hall sensor and never had sync issues or a bad signal. always a clean signal using the hall sensor. DIY has spun the 36-1 tooth wheels upwards of 12000 rpm with clean signal... so the hall sensor might be better for your install.
jeffmarsh750
Post by jeffmarsh750 »
I have had the best of success with an 8-1 wheel and the original DIY silver hall sensor. The red one is a little more temperamental. Cam sensors add sync loss problems at high RPM and it makes no difference on power if waste spark or sequential. Also makes no more power if using more crank teeth. Spark plugs and wires also cause sync loss at high RPM. Too fat or too lean also causes sync loss at high RPM due to secondary miss-fire. My rotor is a Chevrolet distributor rotor with a tooth cut off. Small in diameter and wide helps with all the crank flex and movement. Sensor at 3 or 9 o clock also helps. Have had equal success with an MSD mag sensor (big) and a early Ford diesel 7.3 VR 2 wire short mag sensor. 600hp 1.4L and 6.60@210mph doesn't lie !
Fastest MS powered vehicle on the planet ! 6.60@208mph
