You haven't turned the packet around correctly. You are sending to the wrong address.
Yes, you need to answer every CAN message.
Can Protocol for egt board
Re: Can Protocol for egt board
Can I reduce the fequency of req msseges from MS??
Gesendet von meinem XT1562 mit Tapatalk
No. If you are asking for multiple blocks of data, the requests will all come out back to back as fast as the CAN module can send them.kubeq_sq wrote:Can I reduce the fequency of req msseges from MS??
Hi, yesterday in the night I understood what You have written. Now I can send to MS my readings I made my function to create the ID there is only 1 problem. I have from time to time 1-5 CAN error count... Before my CAN chip is initialized MS shows many CAN errors (ca 50) and the CAN error bits gauge shows max readings. Is it a problem? Is there a specyfic time for the response? my Atmega respons in 80µs - 0.1ms. Can this be a problem?? Because I can't find any mistaken message on the CAN BUS.
Thanks for every help and your patientce It's very nice from You
Hello,
Finally, I finished the EGT Monitor project for 6 cylinders. Custom design for demanding tuners.
I don't know where I can post the thread with the product, so i post at the beginning here. could You tell me where can i post the thread with finished item??
features:
- temperature meeasurment at 6 cylinders separately
- measuring range 0-1023 degrees, with accuracy up to 1 degree
-time measurement 0.2s
-recognition of damaged probe
- sound and visual alarm after exceeding the alarm temperature
-regulation of the alarm temperature to 1 degree
- display values in graphical and digital form
-CAN compatible with Megasquirt 2 and 3
- clear LCD display 128x64 with white backlight and high contrast
- the ability to adjust the intensity of the backlight
- horizontal and vertical orientation, on request it is possible to create your own graphic design
-port usb for uploading software updates
-professional pcb in smd technology
-professional protection and filtering power
-solid aluminum enclosure
-we can make a version for 4 or 5 cylinders with appropriate matching graphic design
You can find us on Facebook:
https://m.facebook.com/story.php?story_ ... 0019437877
If You are interested just write me.
Photos:
features:
Photos:
