Looking for advice on how to set up an oil and fuel pressure sensor. Also wondering if these outputs can be used by an IQ3?? Thanks
Sent from my XT1254 using Tapatalk
Ultimate pressure sensor setup
Re: Ultimate pressure sensor setup
Set up under Generic Sensor Menu. Your Pressure sensor will have calibration voltages. Input them into the Generic Menu for 0v & 5v. I don't have an IQ3 but I'm assuming you are broadcasting to it over the CAN network. So in that setup menu it should correspond to the Generic sensor #bobdj1955 wrote:Looking for advice on how to set up an oil and fuel pressure sensor. Also wondering if these outputs can be used by an IQ3?? Thanks
This begs another question.
Why can't we set the voltage axis of the sensor cal table?
The sensors I have are spec'd at .5v and 4.5v for full range. To get them to read correctly I had to scale the values out to 0v and 5v.
Being able to set the voltage axis would simplify setup.
