So while still fighting a Hot idle issue, i did notice while going down the highway after playing with with MAT curve that VE-A was working fine (super small if any changes, i have the tune where i want it) except i noticed when i should be at 18.4 while cruising, I'm showing 17.4 and VE-A does not seem to care or make changes. so is it smart enough to know what is "really is" before it gets changed by the MAT curve?
the curve almost wants to dip down then back up....
MAT curve vs VE Analyze
81 Porsche 928. 5L 16v, MS3X CNP- full sequential
Re: MAT curve vs VE Analyze
Post the MSL file, too.
added it. i will take a few more this weekend. if the epic rain lets up here in LA>
Yes, post a log showing more of the "cruising" and off-target AFR. There was only about 3 secs. of that last one when the engine wasn't idling, maybe not even enough time for the mixture/combustion to stabilize and let VEAL have a decent chance.
Those sort of numbers are way too lean. There are settings in the EGO settings to ignore the wide band as it must be a bad answer. If you try aiming for 14.5. Or so below about 70 KPA, lots of your issues will so away. The motor will never run smooth at 18. I am suppressed itt runs at all there.
Andy
Andy
I can't imagine that porsche designed those things to run at maxed out egt's for extended periods.
Cheers Luke
Cheers Luke
